Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 5
The rubber gasket surrounding the home button is very thin and tears easily. Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
  • The rubber gasket surrounding the home button is very thin and tears easily.
  • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
  • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
Con la punta del dedo, presiona suavemente, pero no quites, el botón de inicio hacia arriba desde el lado opuesto para liberar un borde de la junta del botón de inicio del panel frontal.
No presiones el botón de inicio hasta el final, solo necesitas obtener una esquina libre, de modo que puedas soltarla con un spudger.
La junta de goma que rodea el botón de inicio es muy delgada. Para evitar que la junta se rompa, recomendamos aplicar una cantidad mínima de calor.
-[* black] Using your fingertip, gently push, but do ***not*** remove, the home button up from the opposite side to free one edge of the home button gasket from the front panel.
-[* icon_caution] Do ***not*** push the home button all the way through—you only need to get a corner free, so that you can pry it free with a spudger.
-[* icon_note] The rubber gasket surrounding the home button is very thin. To prevent the gasket from tearing, we recommend applying a minimal amount of heat.
+[* icon_caution] The rubber gasket surrounding the home button is very thin and tears easily.
+[* black] Apply mild heat (with an [product|IF145-198-2|iOpener], heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
+[* black] Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
