Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 18 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps. If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus. Close the handle on the iSclack, opening the suction cup jaws.
  • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps.
  • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
  • Close the handle on the iSclack, opening the suction cup jaws.
  • Place the bottom of your iPhone in between the suction cups.
  • Position the iSclack's upper suction cup against the display, near the home button.
  • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
Los siguientes dos pasos demuestran el uso de iSclack, una gran herramienta para la segura apertura de el iPhone 6 Plus que recomendamos a cualquiera que haga mas de una reparación. Si no estás usando el iSclack, salta al Paso 4
Si el medidor de profundidad de plástico está conectado en el centro del iSclack, sácalo ahora, no es necesario para teléfonos más grandes como el iPhone 6 Plus
Cierra la manija en el iSclack, abriendo las mandíbulas de la ventosa.
Coloca la parte inferior de su iPhone entre las ventosas.
Coloca la copa de succión superior del iSclack contra la pantalla, cerca del botón de inicio.
Abre las asas para cerrar las mandíbulas del iSclack. Centrar las ventosas y presionarlas firmemente en la parte superior e inferior del iPhone.
[* icon_note] The next two steps demonstrate using the [product|IF145-243|iSclack], a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. '''If you aren't using the iSclack, skip to Step 4down two steps.'''
[* black] If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
[* black] Close the handle on the iSclack, opening the suction cup jaws.
[* black] Place the bottom of your iPhone in between the suction cups.
[* icon_note] Position the iSclack's upper suction cup against the display, near the home button.
[* black] Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
[* icon_note] If your display or back glass is badly cracked, [guide|103487|covering it with a layer of clear packing tape|new_window=true] may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
