Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 2
Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
  • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
  • Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
  • Allow the strip to stretch out before pulling any harder. If you can't feel it stretching, ease up, or it will break.
  • Pull at as low of an angle as you can without snagging the adhesive strip on any of the components along the lower edge of the phone.
  • Don't press down on the battery as you pull the strip.
  • The strip will stretch to many times its original length. Continue pulling slowly until it releases and slips out from underneath the battery.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
Intenta mantener las tiras planas y sin arrugas durante este procedimiento. Las tiras arrugadas se pegarán y romperán en vez de salir fácilmente.
Lentamente tira de la lengüeta adhesiva alejándote de la batería, hacia la base del iPhone.
Permite que la tira se estire antes de jalar más fuerte. Si no la sientes estirar, suelta o se romperá.
Jala en ángulo bajo sin golpear la tira adhesivo o cualquier componente a lo largo del borde inferior del teléfono.
No presiones la batería al jalar de la tira.
La tira se estirará múltiples veces su largo original. Continúa jalando despacio hasta que se libere y salga por debajo de la batería.
Si las lengüetas adhesivas de la batería se rompieran durante el proceso de retirada, usa los dedos o unas pinzas romas para recuperar el restante del adhesivo, y continua tirando.
Si se rompiera cualquier parte de la tira adhesiva bajo la batería y no se pudiera recuperar, intenta retirar el resto de las tiras, y posteriormente proceder como se indica a continuación.
