Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 16 guías que incluyan este paso.
Inglés
Español
Paso 3
Peeling up yellow tape as necessary, remove the following 8 screws:
  • Peeling up yellow tape as necessary, remove the following 8 screws:
  • One 4.5 mm Phillips on the right side of the heat sink.
  • Three 6 mm Phillips near the display.
  • Two large 7.5 mm Phillips with springs (don't forget to remove the springs). If the springs are not releasing, needle nose pliers can help get this done.
  • Two 13 mm screws from the left side of the heat sink and the right side of the fan.
Insertar traducción aquí
