Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 23 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Power off your iPhone before beginning disassembly.
  • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Antes de desarmar tu iPhone, descarga la batería por debajo del 25%. Una batería de litio-ion cargada puede incendiarse y / o explotar si se pincha accidentalmente.
Apaga tu iPhone antes de comenzar el desensamblaje.
Retira los dos tornillos Pentalobe de 3.6 mm situados junto al conector Lightning.
[* icon_caution] Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
[* black] Power off your iPhone before beginning disassembly.
-[* red] Remove the two 3.6 mm-long Pentalobe screws next to the Lightning connector.
+[* red] Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
