Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 29
If you are buying a new upper case from us, the next two steps are not necessary. Your upper case will come with these parts preinstalled. Remove the following screws securing the battery connector cover to the upper case:
  • If you are buying a new upper case from us, the next two steps are not necessary. Your upper case will come with these parts preinstalled.
  • Remove the following screws securing the battery connector cover to the upper case:
  • One 2.5 mm Phillips screw.
  • Two 1.5 mm Phillips screws.
  • Lift the battery connector cover out of the upper case.
Insertar traducción aquí
