Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 9
A bit of prying frees the motherboard assembly from the rear housing. A brassy semicircular ring surrounds the inner housing, providing a ground connection between the motherboard and outer bezel. If you take a close look at the motherboard assembly, you'll notice five spring contact pads that line up with openings through the rear housing—perhaps an access point for programming, testing, or hardware hackers.
  • A bit of prying frees the motherboard assembly from the rear housing.
  • A brassy semicircular ring surrounds the inner housing, providing a ground connection between the motherboard and outer bezel.
  • If you take a close look at the motherboard assembly, you'll notice five spring contact pads that line up with openings through the rear housing—perhaps an access point for programming, testing, or hardware hackers.
  • (Just peel up the FCC sticker under your watch band, without disassembling your Moto 360, to access these pins).
Insertar traducción aquí
