Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 13
  • Let's play "Is it Magnetic?". The rules are pretty much self-explanatory.
  • Would you look at that, it's magnetic. We suspect that the charging coil's sticker backing works like a transformer core, made of up ferrous material that "serves to greatly reduce the magnetizing current and confine the flux to a path which closely couples the windings."
  • Tl;DR: we're thinking this sticker improves the inductive charging efficiency.
  • David clears things up for us:
  • "It is most likely a shielding for the main circuit board. When you are focusing a lot of energy through space, you cannot guarantee it will all end up on the receiver coil. Therefore you will need a shield to absorb any stray energy. Just think, if a wire just happens to be the perfect shape to receive energy, it will likely cook the circuit."
Insertar traducción aquí
