Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 4
Use the tip of a spudger to walk the power button connector out of its socket on the logic board. It is recommended to first push on one side, then the other. Be very careful not to touch any solder joints on the back of the power supply. The power supply's capacitors may be charged enough to give you a dangerous shock.
  • Use the tip of a spudger to walk the power button connector out of its socket on the logic board.
  • It is recommended to first push on one side, then the other.
  • Be very careful not to touch any solder joints on the back of the power supply. The power supply's capacitors may be charged enough to give you a dangerous shock.
Insertar traducción aquí
