Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 4
Disconnect the upper fan connector from the motherboard.
  • Disconnect the upper fan connector from the motherboard.
  • Remove the four spring loaded screws holding the heat sink assembly to the motherboard.
  • When reassembling, ensure that all the screws are equally tightened: thread all screws one turn, then add one turn to each screw in the following order: top left, bottom right, bottom left, top right. Repeat this order until the assembly is firmly seated.
Insertar traducción aquí
