Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Remove the front panel assembly. If the home button ribbon cable sticks to the iPad's rear case, don't try to force it. Gently peel it off the case using a pair of tweezers, and then you can fully remove the front panel assembly.
  • Remove the front panel assembly.
  • If the home button ribbon cable sticks to the iPad's rear case, don't try to force it. Gently peel it off the case using a pair of tweezers, and then you can fully remove the front panel assembly.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
Insertar traducción aquí
