Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
BEFORE REMOVING THE KEYBOARD: It is crucial that the user ground his/herself to avoid damaging sensitive hardware via static electricity. By doing this, user will not have a shock from the product  This can be accomplished by touching a metal lamp that is plugged in, or the back of a desktop computer that is plugged into a wall outlet. ALSO NOTE: A ribbon cable connecting the keyboard to the computer’s motherboard is present (purple marker).  Removing the keyboard too forcefully could damage this cable and/or its connection, possibly causing severe, irreversible damage to the computer.  With the speaker panel absent, the keyboard can be easily removed.  lift the keyboard a few inches from the computer, taking care not to pull beyond the length of the ribbon cable that secures it to the motherboard (purple marker).
  • BEFORE REMOVING THE KEYBOARD: It is crucial that the user ground his/herself to avoid damaging sensitive hardware via static electricity. By doing this, user will not have a shock from the product This can be accomplished by touching a metal lamp that is plugged in, or the back of a desktop computer that is plugged into a wall outlet.
  • ALSO NOTE: A ribbon cable connecting the keyboard to the computer’s motherboard is present (purple marker). Removing the keyboard too forcefully could damage this cable and/or its connection, possibly causing severe, irreversible damage to the computer.
  • With the speaker panel absent, the keyboard can be easily removed. lift the keyboard a few inches from the computer, taking care not to pull beyond the length of the ribbon cable that secures it to the motherboard (purple marker).
  • Identify the ribbon cable connecting the keyboard to the computer’s motherboard (purple marker) and remove it by gently pulling near its point of connection.
  • Once the cable is free from the motherboard, the keyboard is fully separated from the computer.
  • NOTE: If you do not wish to replace the speakers, proceed to "Step 7".
Insertar traducción aquí
