Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 5
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw above the hook for the hand strap.
  • Rotate the camcorder so that the tape compartment is facing you.
  • Remove the single 4.5mm black screw above the hook for the hand strap.
  • Undoing the strap on one end may help.
  • Rotate the camcorder so that the lens is facing you.
  • Remove the single 4.5mm black screw from the front panel.
Insertar traducción aquí
