Saltar al contenido principal
Inglés
Español
Paso 6
Finally you can find the hard disk drive on the back side of the motherboard. Remove the last two screws securing the hard drive. There are two strips of foam to prevent shock under the hard drive, which may stick to the drive due to heat—so, pull slowly away from the SATA connector so you don't damage any components.
  • Finally you can find the hard disk drive on the back side of the motherboard.
  • Remove the last two screws securing the hard drive.
  • There are two strips of foam to prevent shock under the hard drive, which may stick to the drive due to heat—so, pull slowly away from the SATA connector so you don't damage any components.
Insertar traducción aquí
