Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Here you can see the original cracked rear panel and the replacement panel. Next using a Phillips head screwdriver, remove the mounting screws at the bottom of the iPhone. Place them aside carefully as they are really small. Finally, once the screws are out gently apply pressure and slide the screen up to release the panel. Careful not to be too rough with it.
  • Here you can see the original cracked rear panel and the replacement panel.
  • Next using a Phillips head screwdriver, remove the mounting screws at the bottom of the iPhone. Place them aside carefully as they are really small.
  • Finally, once the screws are out gently apply pressure and slide the screen up to release the panel. Careful not to be too rough with it.
Insertar traducción aquí
