Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 20
To remove the upper component board you will be pulling gently on its cable while lifting it up enough to clear the battery, but not high enough to scrape against the rear case. Go slowly and carefully. Insert the tip of a spudger under the upper component board to lift it slightly. Pull the board up and out of the space between the battery and the rear case bezel.
  • To remove the upper component board you will be pulling gently on its cable while lifting it up enough to clear the battery, but not high enough to scrape against the rear case. Go slowly and carefully.
  • Insert the tip of a spudger under the upper component board to lift it slightly.
  • Pull the board up and out of the space between the battery and the rear case bezel.
  • Remove the upper component board.
  • On reassembly, you'll want to reconnect the GPS antenna cable at this point. Use tweezers and work carefully. You may also want to insert and thread (but not tighten) the 2 mm Phillips #000 screw from the lower end of the upper component board. Only tighten after all upper component board screws are inserted and threaded.
Insertar traducción aquí
