Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Use a spudger to walk the power button connector out of its socket on the logic board. It is recommended to first push on one side, then the other. Be  very careful not to touch any solder joints on the back of the power supply. The power supply's capacitors may be charged enough to give you a dangerous shock.
  • Use a spudger to walk the power button connector out of its socket on the logic board.
  • It is recommended to first push on one side, then the other.
  • Be very careful not to touch any solder joints on the back of the power supply. The power supply's capacitors may be charged enough to give you a dangerous shock.
Insertar traducción aquí
