Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side, to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • If you're replacing the display with a new one, you may need to transfer some components from the old display to the new display.
  • During reassembly, head over to our display adhesive guide to install the new adhesive.
Levanta la pantalla del marco y retírala del iMac.
Puede ser necesario levantar lentamente de un lado, para pelar contra el adhesivo restante.
Tenga mucho cuidado al manipular la pantalla: es grande, pesada y está hecha de vidrio.
[* black] Lift the display up from the frame and remove it from the iMac.
[* black] It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass.
[* icon_reminder] If you're replacing the display with a new one, you may need to transfer some components from the old display to the new display.
[* icon_reminder] During reassembly, head over to our [guide|137411|display adhesive guide] to install the new adhesive.
