Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 16
Insert a spudger under the GPS connector end of the upper component board and lift it up off of its adhesive. Be very careful not to scrape the board against the top of the rear case.
  • Insert a spudger under the GPS connector end of the upper component board and lift it up off of its adhesive.
  • Be very careful not to scrape the board against the top of the rear case.
  • The GPS antenna cable will slide out of its ZIF socket when you do this. On reassembly, fit the cable back into the socket as you replace the upper component board.
Insertar traducción aquí
