Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 6
Use the center screw hole of the volume control bracket to tilt it out toward the edge of the case and then pull it up out of its recess. Do not remove the bracket entirely as it is still attached to the button ribbon cable. Do not remove the bracket entirely as it is still attached to the button ribbon cable.
  • Use the center screw hole of the volume control bracket to tilt it out toward the edge of the case and then pull it up out of its recess.
  • Do not remove the bracket entirely as it is still attached to the button ribbon cable.
Insertar traducción aquí
