Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 3
Insert the tip of a spudger between the right speaker and the antenna cable that is routed into the speaker's right side. Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker.
  • Insert the tip of a spudger between the right speaker and the antenna cable that is routed into the speaker's right side.
  • Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker.
  • If the channel is not easily accessible, you can pull the speaker gently away from the case to gain access to the antenna cable.
Insertar traducción aquí
