Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Once all the contacts are desoldered, the old joystick can be removed. Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes. Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
  • Once all the contacts are desoldered, the old joystick can be removed.
  • Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes.
  • Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
Insertar traducción aquí
