Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
These are the solder connections that will need to be desoldered. Since the board is upside down, left will become right. Use a desoldering wick and flux to melt and remove the solder This may take a bit of practice since all the solder will have to be removed. It does help to pull a bit on the joystick while melting the solder and using the wick.
  • These are the solder connections that will need to be desoldered. Since the board is upside down, left will become right.
  • Use a desoldering wick and flux to melt and remove the solder
  • This may take a bit of practice since all the solder will have to be removed. It does help to pull a bit on the joystick while melting the solder and using the wick.
Estas son las conexiones soldadas que necesitarán ser desoldadas. Como el circuito está al revés, la izquierda se convertirá en la derecha.
Usar una mecha desoldadora y un fundente para derretir y eliminar la soldadura
Esto puede requerir un poco de práctica ya que toda la soldadura tendrá que ser retirada. Ayuda un poco tirar de la palanca del mando mientras se derrite la soldadura.
