Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the hard drive screw labeled with a #1 Phillips head screwdriver  as indicated in the picture, then use a flat edge tool to pry the cover off. Use the plastic flap to pull the hard drive out of its slot. Use the plastic flap to pull the hard drive out of its slot.
  • Remove the hard drive screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
  • Use the plastic flap to pull the hard drive out of its slot.
Insertar traducción aquí
