Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case. Be careful not to snag the speaker cable on the screw hole post in the side of the case. Be careful not to snag the speaker cable on the screw hole post in the side of the case.
  • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
  • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
Levanta la esquina del altavoz izquierdo y deslízalo fuera de la batería para removerlo de la caja superior.
Ten cuidado de no enganchar el cable del altavoz en el orificio del tornillo al lado de la caja.
[* black] Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
[* icon_caution] Be careful '''not''' to snag the speaker cable on the screw hole post in the side of the case.
