Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 17
After peeling the button cables up from their adhesive, they pop out of their button caves. The plastic button covers remain stubbornly in place. The mechanical button on the cable is the bit most likely to fail, but is easy enough to replace. However, you may have to live with scuffed exterior buttons if you drop your S5 Mini.
  • After peeling the button cables up from their adhesive, they pop out of their button caves.
  • The plastic button covers remain stubbornly in place. The mechanical button on the cable is the bit most likely to fail, but is easy enough to replace. However, you may have to live with scuffed exterior buttons if you drop your S5 Mini.
Después de despegar los cables de los botones de su adhesivo, salen de sus cuevas de botones.
Las cubiertas de plástico para botones permanecen obstinadamente en su lugar. El botón mecánico en el cable es lo más probable que falle, pero es bastante fácil de reemplazar. Sin embargo, es posible que deba vivir con botones externos desgastados si deja caer su S5 Mini.
