Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 9
Samsung has made our life a little easier by placing the daughterboard connector on top of the motherboard, enabling us to remove the daughterboard without the motherboard's approval removal. After removing the daughterboard, we spy an extra antenna interconnect cable that wasn't present in our Galaxy S5 teardown unit. We suspect this is for the Band 7 antenna (for European coverage).  The green coax cable connects to the standard WCDMA and LTE bands, but  Band 7 is LTE-only, and operates at 2.5 GHz — so it's a separate antenna for better antenna performance.
  • Samsung has made our life a little easier by placing the daughterboard connector on top of the motherboard, enabling us to remove the daughterboard without the motherboard's approval removal.
  • After removing the daughterboard, we spy an extra antenna interconnect cable that wasn't present in our Galaxy S5 teardown unit.
  • We suspect this is for the Band 7 antenna (for European coverage). The green coax cable connects to the standard WCDMA and LTE bands, but Band 7 is LTE-only, and operates at 2.5 GHz — so it's a separate antenna for better antenna performance.
Samsung ha hecho nuestra vida un poco más fácil al colocar el conector de la placa hija en la parte superior de la placa madre, lo que nos permite eliminar la placa hija sin la e la aprobación de la placa madre.
Después de retirar la placa hija, detectamos un cable de interconexión de antena adicional que no estaba presente en nuestra unidad de desmontaje Galaxy S5.
Sospechamos que esto es para la antena de banda 7 (para cobertura europea). El cable coaxial verde se conecta a las bandas estándar WCDMA y LTE, pero la banda 7 es solo para LTE y funciona a 2.5 GHz, por lo que es una antena independiente para un mejor rendimiento de la antena.
