Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
HDD is an abbreviation for "hard disk drive." Before removing the HDD, remove the temperature sensor that is mounted directly on the hard drive. The sensor is attached to the hard drive using adhesive tape and a protective foam cushion. Peel off the foam and set the sensor aside. Be gentle with the foam because you will reuse it to connect the sensor to the new HDD.
Remove the hard drive
  • HDD is an abbreviation for "hard disk drive."
  • Before removing the HDD, remove the temperature sensor that is mounted directly on the hard drive. The sensor is attached to the hard drive using adhesive tape and a protective foam cushion.
  • Peel off the foam and set the sensor aside. Be gentle with the foam because you will reuse it to connect the sensor to the new HDD.
  • Lift the HDD out of the device and disconnect the two SATA cables from the HDD.
HDD es el acrónimo de "disco duro".
Antes de quitar el HDD, quita el sensor de temperatura que está montado directamente en el disco duro. El sensor está unido al disco duro por una cinta adhesiva y cubierta por una funda protectora de espuma.
Pela la espuma y deja el sensor a un lado. Se gentil con la espuma porque la re-usaras para conectar el sensor al nuevo HDD.
Levanta el HDD afuera del dispositivo y desconecta los dos cables SATA del HDD.
