Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 25
Open the MacBook Pro a little wider than 90 degrees, and place it on end, as shown. While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
  • Open the MacBook Pro a little wider than 90 degrees, and place it on end, as shown.
  • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
  • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
  • Remove the last remaining T8 Torx screw securing the display to the upper case.
Insertar traducción aquí
