Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 10
Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
  • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
  • The three cables are coded with black sleeves of different lengths. During reassembly:
  • Connect the long-sleeved cable to the center socket.
  • The short-sleeved cable connects next to the screw.
  • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  • When reconnecting the antenna cables, run them over the camera cable, not underneath.
Insertar traducción aquí
