Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 12
Stitch this second row the same way you did the first, but in the opposite direction. This time, go under the rows of knit you previously went over, and vice versa. When you reach the end of this second row, turn around and continue stitching in the previous direction. Stitch rows back and forth until you have worked about a centimeter past the hole.
  • Stitch this second row the same way you did the first, but in the opposite direction. This time, go under the rows of knit you previously went over, and vice versa.
  • When you reach the end of this second row, turn around and continue stitching in the previous direction. Stitch rows back and forth until you have worked about a centimeter past the hole.
  • Don't forget to pull the thread taut after each stitch. If you are new to sewing, take your time, slowly completing each stitch.
Coser esta segunda fila de la misma manera que hiciste la primera, pero en la dirección opuesta. Esta vez, ve debajo de las hileras de punto que pasaste anteriormente y viceversa.
Cuando llegues al final de esta segunda fila, da la vuelta y continúa cosiendo en la dirección anterior. Coser las filas de ida y vuelta hasta que hayas trabajado un centímetro más allá del agujero.
No olvides tensar el hilo después de cada puntada. Si eres nuevo en la costura, tómate tu tiempo y completa lentamente cada puntada.
