Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
After removing the front bezel,  you need to remove the 8ea 12mm T8 screws around the perimeter of the LCD Rotate the iMac so the TOP EDGE is facing you and GENTLY  lift the LCD up about 75mm (3in) and prop up the LCD with something NON CONDUCTIVE.
  • After removing the front bezel, you need to remove the 8ea 12mm T8 screws around the perimeter of the LCD
  • Rotate the iMac so the TOP EDGE is facing you and GENTLY lift the LCD up about 75mm (3in) and prop up the LCD with something NON CONDUCTIVE.
  • Lifting the LCD in this way exposes the rear of the PSU to allow access to the PSU connector. When the imac is connected to the mains (even if switched OFF) there is MAINS VOLTAGE on this board
Insertar traducción aquí
