Saltar al contenido principal
Inglés
Español
Paso 2
Digitizers allow your device to recognize when and where you touch the screen. Digitizers themselves do not produce your device's visuals—that's the job of the display panel. They can usually be identified by a large glass panel, and a digitizer ribbon cable that connects it to the rest of the device. A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
Digitizer
  • Digitizers allow your device to recognize when and where you touch the screen. Digitizers themselves do not produce your device's visuals—that's the job of the display panel.
  • They can usually be identified by a large glass panel, and a digitizer ribbon cable that connects it to the rest of the device.
  • A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
Los digitalizadores permiten que tu dispositivo reconozca cuándo y dónde toca la pantalla. Los digitalizadores por sí mismos no producen las imágenes de tu dispositivo, ese es el trabajo del panel de visualización.
Por lo general, se pueden identificar mediante un gran panel de vidrio y un cable plano del digitalizador que lo conecta con el resto del dispositivo.
Un número creciente de dispositivos modernos, como el iPhone, están combinando el digitalizador y el panel de visualización en un único ensamblaje de pantalla. Esto significa que si alguno de los componentes falla, es necesario reemplazar todo el ensamblaje.
