Saltar al contenido principal
Inglés
Español
Paso 11
The central processing unit (CPU) is a lot like the "brain" of a device. It handles all of the necessary calculations to run the operating system and all of your applications. Although CPUs can vary greatly in size, it's generally fairly easy to identify them. Most devices have a heatsink (see previous step) keeping the CPU cool. Find the heatsink, and you'll generally find the CPU hiding underneath. Be careful when removing CPUs, because they can be very delicate. Additionally, some CPUs (Apple's A7 for example) can't be removed because they are soldered into the motherboard. If a CPU doesn't come off easily, do NOT try to desolder it, as you might cause irreparable damage to it.
CPU
  • The central processing unit (CPU) is a lot like the "brain" of a device. It handles all of the necessary calculations to run the operating system and all of your applications.
  • Although CPUs can vary greatly in size, it's generally fairly easy to identify them. Most devices have a heatsink (see previous step) keeping the CPU cool. Find the heatsink, and you'll generally find the CPU hiding underneath.
  • Be careful when removing CPUs, because they can be very delicate. Additionally, some CPUs (Apple's A7 for example) can't be removed because they are soldered into the motherboard. If a CPU doesn't come off easily, do NOT try to desolder it, as you might cause irreparable damage to it.
La unidad central de procesamiento (CPU) se parece mucho al "cerebro" de un dispositivo. Maneja todos los cálculos necesarios para ejecutar el sistema operativo y todas sus aplicaciones.
Aunque las CPUs pueden variar mucho en tamaño, generalmente es bastante fácil identificarlas. La mayoría de los dispositivos tienen un disipador de calor (ver paso anterior) que mantiene la CPU fría. Encuentra el disipador de calor, y generalmente encontrarás la CPU escondida debajo.
Ten cuidado al retirar las CPUs, ya que pueden ser muy delicadas. Además, algunas CPUs (por ejemplo, la A7 de Apple) no se pueden quitar porque están soldadas a la placa madre. Si una CPU no se desprende fácilmente, NO intentes desoldarla, ya que podría causarle daños irreparables.
[title] CPU
-[* black] The central processing unit (CPU) is a lot like the "brain" of a device. It handles all of the the necessary calculations to run the operating system and all of your applicataions.
+[* black] The central processing unit (CPU) is a lot like the "brain" of a device. It handles all of the necessary calculations to run the operating system and all of your applications.
[* black] Although CPUs can vary greatly in size, it's generally fairly easy to identify them. Most devices have a heatsink (see previous step) keeping the CPU cool. Find the heatsink, and you'll generally find the CPU hiding underneath.
[* icon_caution] Be careful when removing CPUs, because they can be very delicate. Additionally, some CPUs (Apple's A7 for example) can't be removed because they are soldered into the motherboard. If a CPU doesn't come off easily, do ***NOT*** try to desolder it, as you might cause irreparable damage to it.
