Saltar al contenido principal
Inglés
Español
Paso 19
The flash assembly of a camera provides a quick burst of light when taking a photo that can brighten up otherwise dark environments. To identify the flash assembly, look for a small board that attaches to the rectangular light on the front of the device. When handling the flash assembly, make sure you have removed the battery from the camera. Most flash assemblies have capacitors, which can shock you if you touch the leads. It's also a good idea to make sure the capacitor has been discharged before handling it.
Flash Assembly
  • The flash assembly of a camera provides a quick burst of light when taking a photo that can brighten up otherwise dark environments.
  • To identify the flash assembly, look for a small board that attaches to the rectangular light on the front of the device.
  • When handling the flash assembly, make sure you have removed the battery from the camera. Most flash assemblies have capacitors, which can shock you if you touch the leads. It's also a good idea to make sure the capacitor has been discharged before handling it.
El ensamblaje del flash de una cámara proporciona una rápida ráfaga de luz cuando se toma una foto que puede iluminar entornos que de otro modo serían oscuros.
Para identificar el ensamblaje del flash, busca una pequeña placa que se fije a la luz rectangular en la parte frontal del dispositivo.
Al manipular el ensamblaje del flash, asegúrate de haber quitado la batería de la cámara. La mayoría de los ensamblajes de flash tienen condensadores, que pueden producirle una descarga eléctrica si tocas los cables. También es una buena idea asegurarse de que el condensador ha sido descargado antes de manipularlo.
