Saltar al contenido principal
Inglés
Español
Paso 9
The motherboard is like the nervous system of your device. Without a motherboard, your device is just a useless hunk of electronics! Motherboards are generally very easy to identify, because they're one of the largest components in your device. Many of the other components inside your device connect to the motherboard. "Motherboard" is a generic name for the largest circuit board in a device. Apple calls their motherboards "Logic boards." This is brand-specific nomenclature. So unless you have an Apple device, you are working with a "motherboard."
Motherboard
  • The motherboard is like the nervous system of your device. Without a motherboard, your device is just a useless hunk of electronics!
  • Motherboards are generally very easy to identify, because they're one of the largest components in your device. Many of the other components inside your device connect to the motherboard.
  • "Motherboard" is a generic name for the largest circuit board in a device. Apple calls their motherboards "Logic boards." This is brand-specific nomenclature. So unless you have an Apple device, you are working with a "motherboard."
La placa madre es como el sistema nervioso de tu dispositivo. Sin una placa madre, tu dispositivo es sólo un pedazo inútil de electrónica!
Las placas madre son generalmente muy fáciles de identificar, porque son uno de los componentes más grandes de tu dispositivo. Muchos de los otros componentes dentro de tu dispositivo se conectan a la placa madre.
"Placa madre" es un nombre genérico para la placa de circuito más grande de un dispositivo. Apple llama a sus placas madre "placas lógicas". Se trata de una nomenclatura específica de la marca. Así que a menos que tengas un dispositivo Apple, estás trabajando con una "placa madre".
