Saltar al contenido principal
Inglés
Español
Paso 8
Most devices have some sort of casing around them which protects their internal components. Casings are made from a variety of materials, including plastic, aluminum, and glass. Laptops often have a top and bottom case that needs to be taken apart to access the internals. Phones/cameras on the other hand often have front and rear cases that separate to reveal the internals.
Casing
  • Most devices have some sort of casing around them which protects their internal components. Casings are made from a variety of materials, including plastic, aluminum, and glass.
  • Laptops often have a top and bottom case that needs to be taken apart to access the internals.
  • Phones/cameras on the other hand often have front and rear cases that separate to reveal the internals.
La mayoría de los dispositivos tienen algún tipo de carcasa a su alrededor que protege sus componentes internos. Las carcasas están hechas de una variedad de materiales, incluyendo plástico, aluminio y vidrio.
Los portátiles suelen tener una carcasa superior e inferior que hay que desmontar para acceder a los componentes internos.
Por otro lado, los teléfonos/cámaras a menudo tienen carcasas delanteras y traseras que se separan para revelar las partes internas.
