Saltar al contenido principal
Inglés
Español
Paso 3
The display panel is what shows all of your device's visuals. Although there are a wide variety of display panel types and sizes (LCD, LED, OLED, AMOLED), they're typically the most prominent feature of the device, which makes them very easy to identify. Look for a ribbon cable that connects the panel to the rest of the device. A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
Display Panel
  • The display panel is what shows all of your device's visuals.
  • Although there are a wide variety of display panel types and sizes (LCD, LED, OLED, AMOLED), they're typically the most prominent feature of the device, which makes them very easy to identify. Look for a ribbon cable that connects the panel to the rest of the device.
  • A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
El panel de pantalla es lo que muestra todos los elementos visuales de tu dispositivo.
Aunque hay una gran variedad de tipos y tamaños de pantallas (LCD, LED, OLED, AMOLED), suelen ser la característica más destacada del dispositivo, lo que hace que sean muy fáciles de identificar. Busca un cable plano que conecte el panel con el resto del dispositivo.
Un número creciente de dispositivos modernos, como el iPhone, están combinando el digitalizador y el panel de pantalla en un único ensamblaje de pantalla. Esto significa que si alguno de los componentes falla, es necesario reemplazar todo el ensamblaje.
