Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Remove the screw that is on the right side of the panel facing you. Now rotate the device 180 degrees and remove the second screw.
  • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
  • Remove the screw that is on the right side of the panel facing you.
  • Now rotate the device 180 degrees and remove the second screw.
  • Remove all screws with a phillips head screwdriver.
Insertar traducción aquí
