Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer. Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components. Locate and slide the 2-battery locks to disconnect the battery.
  • If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer.
  • Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components.
  • Locate and slide the 2-battery locks to disconnect the battery.
  • Remove the battery by sliding it out away from the computer (horizontal with the casing).
Insertar traducción aquí
