Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 5
Removing the GPS antenna can be very challenging. The method shown in the following steps is one that worked for us. However, you should only follow this guide if you are replacing  the GPS antenna with a new one, as this could irreparably damage the antenna. Using a set of tweezers, gently lift the GPS antenna cable to begin peeling the antenna off of the rear case.
  • Removing the GPS antenna can be very challenging. The method shown in the following steps is one that worked for us. However, you should only follow this guide if you are replacing the GPS antenna with a new one, as this could irreparably damage the antenna.
  • Using a set of tweezers, gently lift the GPS antenna cable to begin peeling the antenna off of the rear case.
Insertar traducción aquí
