Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
In this step you will remove the three pieces of tape securing the right cell antenna cable to the rear case. Use the tip of a spudger to start each piece, and then the flat end to smoothly peel the tape up without tearing it. Use the tip of a spudger to start each piece, and then the flat end to smoothly peel the tape up without tearing it.
  • In this step you will remove the three pieces of tape securing the right cell antenna cable to the rear case.
  • Use the tip of a spudger to start each piece, and then the flat end to smoothly peel the tape up without tearing it.
Insertar traducción aquí
