Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 34
Slide an opening pick under the logic board between it and the battery. Slide the pick from the base to the center of the logic board to cut the adhesive. Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
  • Slide an opening pick under the logic board between it and the battery.
  • Slide the pick from the base to the center of the logic board to cut the adhesive.
  • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
Insertar traducción aquí
