Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Paso 14
Switch on your multimeter, and set the dial to resistance mode. Resistance is measured in ohms, indicated by the Ω symbol.
  • Switch on your multimeter, and set the dial to resistance mode.
  • Resistance is measured in ohms, indicated by the Ω symbol.
  • Most multimeters are not autoranging, meaning you will need to set the correct range for the resistance you expect to measure. If you're not sure, start with the highest setting.
Enciende tu multimetro y ajusta el dial al modo de resistencia.
La resistencia se mide en ohmios, indicado por el simbolo Ω.
La mayoria de multimetros no son auto-oscilantes, eso significa que tendras que establacer el rango correcto para la resistencia que deseas medir. Si no estas seguro, empieza con el ajuste maximo.
