Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 7
In this mode, the multimeter sends a little current through one probe, and measures what (if anything) is received by the other probe. If the probes are connected—either by a continuous circuit, or by touching each other directly—the test current flows through. The screen displays a value of zero (or near zero—in this case, 0.8). Very low resistance is another way of saying that we have continuity.
  • In this mode, the multimeter sends a little current through one probe, and measures what (if anything) is received by the other probe.
  • If the probes are connected—either by a continuous circuit, or by touching each other directly—the test current flows through. The screen displays a value of zero (or near zero—in this case, 0.8). Very low resistance is another way of saying that we have continuity.
  • If no current is detected, it means there's no continuity. The screen will display 1 or OL (open loop).
En este modo, el multimetro envia un poco de corriente por una sonda y mide lo que es recibido por la otra sonda.
Si las sondas son conectadas—ya sea por un circuito interrumpido, o por directamente tocando las dos sondas—la corriente de prueba fluye a traves de las dos sondas. La pantalla demuestra un valor de 0 (o casi cero—en este caso, 0.8). Una resistencia baja es otra manera de decir que tenemos continuidad.
Si ninguna corriente es detectada, eso significa que no hay continuidad. La pantalla demostrara 1 u OL (open loop).
