Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 8
To complete your continuity test, place one probe at each end of the circuit or component you want to test. It doesn't matter which probe goes where; continuity is non-directional.
  • To complete your continuity test, place one probe at each end of the circuit or component you want to test.
  • It doesn't matter which probe goes where; continuity is non-directional.
  • As before, if your circuit is continuous, the screen displays a value of zero (or near zero).
  • If the screen displays 1 or OL (open loop), there's no continuity—that is, there's no path for electric current to flow from one probe to the other.
Para completar tu prueba de continuidad, pon una sonda en cada lado del circuito o componente que queries probar.
No importa donde coloques cada sonda;la continuidad no és direccional.
Como antes, si su circuito es continuo, la pantalla mostrará un valor de zero (o casi zero).
Si la pantalla muestra 1 u OL (open loop), no hay continuidad—es decir, no hay camino para que la corriente fluya de una sonda a la otra.
