Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
The multimeter tests continuity by sending a little current through one probe, and checking whether the other probe receives it. If the probes are connected—either by a continuous circuit, or by touching each other directly—the test current flows through. The screen displays a value of zero (or near zero), and the multimeter beeps. Continuity!
  • The multimeter tests continuity by sending a little current through one probe, and checking whether the other probe receives it.
  • If the probes are connected—either by a continuous circuit, or by touching each other directly—the test current flows through. The screen displays a value of zero (or near zero), and the multimeter beeps. Continuity!
  • If the test current isn't detected, it means there's no continuity. The screen will display 1 or OL (open loop).
El multímetro prueba la continuidad mediante el envío de un poco de corriente de la propia pila del multimetro a través de una sonda, y comprueba si la otra sonda la recibe.
Si las sondas están conectadas, ya sea por un circuito continuo, o tocando directamente entre sí, la corriente de prueba fluye a través de ellas. La pantalla mostrará un valor de cero (o casi cero), y el multimetro pitará.¡Hay Continuidad!
Si no se detecta la corriente de prueba, significa que no hay continuidad. La pantalla mostrará 1 u OL (bucle abierto).
