Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 11
Sometimes removing the connector from its socket isn’t enough; an additional step or two is required to free up the cable. Here we have a Lightning port ribbon cable that is lightly glued into place. To remove it, carefully slide a spudger or guitar pick underneath the cable, freeing it from the adhesive.
Glued-Down Cables
  • Sometimes removing the connector from its socket isn’t enough; an additional step or two is required to free up the cable. Here we have a Lightning port ribbon cable that is lightly glued into place.
  • To remove it, carefully slide a spudger or guitar pick underneath the cable, freeing it from the adhesive.
  • For particularly delicate or stubborn cables, a little heat from a heat gun, hair dryer, or our handy iOpener will help soften the adhesive.
A veces, quitar el conector de su zócalo no es suficiente. Se requiere uno o dos pasos adicionales para liberar el cable. Aquí tenemos un cable plano de puerto Lightning que está ligeramente pegado en su lugar.
Para quitarlo, desliza con cuidado una herramienta plástica o una púa de guitarra debajo del cable, liberándolo del adhesivo.
Para cables particularmente delicados o resistentes, un poco de calor con una pistola de calor, un secador de pelo o nuestro práctico iOpener ayudará a suavizar el adhesivo.
