Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 14
These are often found in pocket calculators, DECT phones, and other devices with a simple monochrome 7-segment or low-resolution display. They are used to connect the conductive tracks on the glass of an LCD to a set of pads on a circuit board below. (These displays sometimes suffer from dead segments or rows of pixels.)
Elastomeric (ZEBRA) connectors
  • These are often found in pocket calculators, DECT phones, and other devices with a simple monochrome 7-segment or low-resolution display. They are used to connect the conductive tracks on the glass of an LCD to a set of pads on a circuit board below. (These displays sometimes suffer from dead segments or rows of pixels.)
  • Screws or twisted metal tabs commonly secure a metal frame, which compresses the elastomeric strip between the LCD and the circuit board. Release these to separate the LCD and the elastomeric strip.
  • In the photo, bright light reveals the conductive traces on the glass of the LCD. Beneath this is the elastomeric strip, and hidden beneath that are the tracks on the circuit board—in the same patterns as the ones on the glass.
  • The elastomeric strip consists of conductive and non-conductive layers which alternate along its length. There are several for every connection to the LCD, eliminating the need for precise alignment.
A menudo se encuentran en calculadoras de bolsillo, teléfonos y otros dispositivos con una pantalla monocromática simple de 7 segmentos. Se utilizan para conectar las pistas conductoras en el cristal de una pantalla LCD a un conjunto de almohadillas en una placa de circuito (Estas pantallas a veces sufren de segmentos muertos o filas de píxeles).
Los tornillos o las pestañas metálicas retorcidas generalmente aseguran un marco de metal, que comprime la tira elastomérica entre la pantalla LCD y la placa de circuito. Libéralos para separar la pantalla LCD y la tira elastomérica.
En la foto, la luz brillante revela las huellas conductoras en el cristal de la pantalla LCD. Debajo de esto está la tira elastomérica, y oculta debajo de eso están las pistas en la placa de circuito, en los mismos patrones que las del vidrio.
La tira elastomérica consiste en capas conductoras y no conductoras que se alternan a lo largo de su longitud. Hay varios para cada conexión a la pantalla LCD, lo que elimina la necesidad de una alineación precisa.
