Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 21 guías que incluyan este paso.
Inglés
Español
Paso 6
Remove the following 10 screws from the bottom case:
  • Remove the following 10 screws from the bottom case:
  • Three 1.7 mm Phillips from the front edge of the battery compartment.
  • One 3.9 mm T8 Torx to the right of the memory card.
  • One 6.9 mm T8 Torx at the left edge of the memory compartment.
  • Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
  • Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
Insertar traducción aquí
